JOHI's avatar
JOHI
8 years ago
Sharing of signals over different processes in modelsim not working as expected ?
Hello, For my test bench I have created a test bench with 3 separate processes. The first process generates a clock. The second process sets a signal " enable_clock" after reading a file with stim...
  • Tricky's avatar
    8 years ago
    1. That is because enable_clock is set to '1' after the first falling edge of the clock, and it remains at '1'.
    The thrid process (main_data_gen) is waiting for enable_clock to toggle to '1' after the second clock. But it already at '1', and hence waits forever.
    Wait until is triggered by a 'event on the sensitivy list (the signals you are waiting for).
    the workaround is to do this:
    if enable_clock /= '1' then
      wait until enable_clock = '1';
    end if;
    2. Now to comment on the code. Why are you manually waiting for edges on the clock? VHDL has the build in functions rising/falling_edge, so its usually much better to use those on the code, and is more readable. in addition, use loops to wait for a defined number of clocks:
    for i in 1 to 10 loop  -- wait for 10 clocks
      wait until rising_edge(clk);
    end loop;
    or even better, in some tools package, define a procedure to wait for a specified number of clocks (its a pretty standard thing to want to do in any testbench:
    procedure wait_for_clks( constant n   :    integer;
                             signal   clk : in std_logic ) is
    begin
      for i in 1 to n loop
      end loop;
    end procedure;
    process
    begin
      wait_for_clks(10, clk);
    end process;
    3. Next, if you want a process to halt, putting wait until 0=1; will wait forever, but its a fairly nonsense piece of code. Why not simply write "wait", as a single wait will wait forever
    stim_proc : process
    begin
      ....do something
      .. do something else
      wait;    -- waits forever;
    end process;
    4. For the PSD_data_table, why not set the values in an initialisation function, rather than assign them in a process?
