Yes. Consider the channel
Ok, I'll look at the channels
Thanks - Altera_Forum
Are you talking about two different executables on the host? They would have to both load the same .aocx file in which you have the two kernels.
The first executable would program the FPGA, but I don't know if the second one won't reprogram it while the first kernel has started running. That's something to try. - Altera_Forum
Yes that's what I was thinking about. I'll try and let you know (in few months at least)
If it's not possible, the solution can be multi-thread. Is there any limitation on concurrent accesses from the host to the same kernel ? Thanks - Altera_Forum
What do you mean by "accessing" a kernel?
What I would do is, in an application containing the functionality of both programs, have one (or more) command queue by functionality. Then, you program the FPGA once but enqueue the copies and kernels for each functionality in their respective queue. I hope this helps.
