17 years agosetup and hold time with set_input_delay
Hello, I have some problem understanding the set_input_delay min and max constraint. Assume that you have an interface that is connected to an FPGA. This interface has a clock (Clk) and a...
17 years agoI'm not following the whole post. First off, don't spend forever reading the documentation. When you have a few constraints in, do something like the following, where you put in the portname you want to analyzer:
report_timing -setup -from [get_ports your_portname*] -detail full_path -panel_name "Inputs setup" report_timing -hold -from [get_ports your_portname*] -detail full_path -panel_name "Inputs hold" At that point, look at the Data Path tab in excrutiating detail and figure out what it's calculating. Your clock relationship will be reflected in the launch and latch times, the external delays will just be a line item, and everything else should be either clock or data delay in the FPGA. Yours is a source synchronous output with clock and data edge aligned. Is it single-data rate or double-data rate? How are you shifting your clock to center it's edge on the data? (For single data rate you can just invert it at the capture register, or do a 180 degree phase shift in a PLL. If it's double-data rate, you'll want to use a PLL and phase-shift it 90 degree. Also, the PLL should be in source-synchronous mode.)
