8 years agoSetup ALTGX_RECONFIG instances for two ALTGX instances on the same transceiver block
How to setup and connect one ALTGX_RECONFIG instances for two ALTGX instances on the same transceiver-block ? Note: * Quartus 14.1 * FPGA: Cyclone IV GX EP4CGX15F14C6N Each ALTGX ins...
8 years agoHi,
Tested with Quartus 13 and 17.1, on both of them the issue is fixed and there is no such error. B.T.W I had to set to 8 "what is the number of channels controlled by the reconfig controller?" so ALTGX_RECONFIG instances will have reconfig_fromgxb[9..0] although I have only two channels (PCIe and Basic). why ? It would be much simpler to understand and connect if GX reconfig port would be a seperate ALT instance take care the all PHY channels and not spread between ALTGX instances.
