15 years ago --- Quote Start --- Can you please let me know how to get the BeMicro Cyclone iii eval board working on Win 7 64bit which is my new machine (I miss XP Pro). I would appreciate the help very much, Thanks, Dale --- Quote End --- Scratch that. I gave up on the Win7 64bit machine that IT gave me. However I am now stuck with xp pro 64 bit , good luck getting 32 bit hardware now. So far all my development applications have installed with the exception that I can not get the USB Blaster driver to install properly which seems to be required to support the BeMicro eval board. - When I run the setup file under the BeMicro\programmer folder, the install process seems to work to install the jtag_hw_arrow_usb_blaster.dll When I check out drivers under Device Manager I see 2 drivers installed: - Arrow USB-Blaster Port A - Arrow USB-Blaster Port B - However, when I work through the BeMicro tutorial and get to the 5.3 section part where it wants me to click Hardware Setup and select Arrow-USB-Blaster in Quartus (I am using quartus v10 sp1), the only option I see is "No Hardware" I have to get results rolling fast, can someone help me get past the XP Pro 64 bit USB Blaster driver Quartus v10 recognition issue. Thank you very much, Dale
