12 years agosetting default version of Quartus II in Windows 7
I installed Quartus II 14.0 but I don't want to switch over to it yet. I'm still running 13.0sp1. How do I make 13.0sp1 the default so that when I double-click a .qpf file the project opens in 13.0sp...
10 years agoFor some reason, the behavior is different with my Windows 7 64-Bit version, as already reported
--- Quote Start --- Neither does starting a specific Quartus version switch the QUARTUS_ROOTDIR environment variable nor is the environment variable examined when deciding about the actual *.qpf open action. --- Quote End --- I conclude from your post, that the problem is not specific to Windows 7 64-Bit as such. Thanks for clarifying.
