16 years ago
set PLL_COMPENSATE
The alt_pll_megafunction user guide states:
"Note that for Source-Synchronous mode and Zero Delay Buffer
mode, you need to make assignments (in this case, the
PLL_COMPENSATE assignment) in addition to setting the
appropriate mode in the megafunction."
The Quartus II Settings File Manual defines this constraint as:
set_instance_assignment -name PLL_COMPENSATE -to <to> -entity <entity name> <value>
Does anyone have an actual example of this setting?
What should be used for <entity>?
I assume the <to> is the pin name?
Thanks in advance,
A
