15 years ago --- Quote Start --- Is the set_output_delay a part of the Altera standard library and if so how do I initialize it? --- Quote End --- Hi lew3611, Bongo is right, it is an command for the TimeQuest Timing Analyzer. It defines the output timing requirements ( that depends on the input requirements of the receiving device). It does not mean that you switch on/off delays. Kind regards GPK
