JOter
7 years agoSet_output_delay commands does not apply to the output signal
We have a design where we control an external RAM memory. We generate the CLK and control memory signals in a FPGA (Cyclone IV). The CLK signal is generated using a PLL, with 180º phase shift. The ...
JOter
6 years agoHi,
It seems I have not explain correctly.
In the input case, the setting is defined correctly the setting, but I modified it to a wrong value to confirm that the constraints apply as it was expected.
In reference to the output setting, it is also working properly but I want to test that I'am able to modified the CLK-signal timing using a wide range of max/min (from 0 to 12 for example) "output_delay". But the real delay is the same.
