10 years agoset_max_skew command
I'm clocking a data bus out of my Cyclone V and want to constrain the maximum skew between data lines. I'm using; # 100 ps max skew set_max_skew -to [get_ports data_out [*]] 0.1 It seem...
10 years ago --- Quote Start --- OK, agreed. But if I set my constraint to a value that (I think) can't possibly pass timing, for example; set_max_skew -to [get_ports data_out [*]] 0.0 Then wouldn't I expect TQ to report a failure? --- Quote End --- It depends on your io constraints i.e set_output_delay figures and clock rate. skew does not tell TQ what are your actual constraints (clock data offset). I know skew method is used for some cases of DDR if the external chip asks for skew only but I am not sure then how TQ check the tSU/tH. I believe in such cases the external chip doesn't care about data/clock offset as it may have automated logic to align.
