lambert_yu
Contributor
5 years agoset_max_delay and set_min_delay is no sense for project compile
Hi sir,
I face one problem, and I have no idea for the set_max_delay and set_min_delay constrains, the problem as follows:
I want to constrains the delay from the reg_q to the port_o, b...
KhaiChein_Y_Intel
5 years agoHi,
It depends on the location of the source and destination. If you set min/max delay and you see the delay in the Timing Analyzer exceeds the value that you set, the value in the Timing Analyzer is min/max for the same source/destination location.
KhaiY
lambert_yu
Contributor
5 years agoHi KhaiY,
If so, I want to know, if the max/min value which I set is not satisfied by software, will it provide violation message? Now, it does not present this message in timing report, it's normal?
BR,
Lambert
