10 years agoset_input_delay constraint
Hi, I have a bidirectional synchronous interface which I want to constrain. Without any constraints the interface doesn't work and with the constraints I tried it works, but I get the message f...
10 years agoI don't know how it's failing and what you have now(I assume the outputs are registers, they just have combinatorial logic before they go to the pin). If so, registering them would make them have a faster output time. Of course, the fitter can use IO delay chains to slow down the output time too, if it deems it necessary for hold. It is standard practice to register your data outputs, but I don't know the specifics of your situation well enough to say if it will help. It will probably help, and should not hurt.
