9 years agoSet GPIO pins with multiple voltage levels
Hello, I am using a DE0-Nano FPGA and Quartus II 14.0. I am able to set the voltage of GPIO pins to either a high or low value based on a binary string of 0s and 1s. However, I would...
9 years agoI am experimenting with different ways of sending data as part of a research project. If an FPGA is not the right device for sending multiple voltage levels what would be a good device that I could use for this?
Also as mentioned in my previous post is there is a signal mixer block in Quartus that I could use to mix 2 voltage values and output 3 voltage values? If so where can I find this.
