set_global_assignment -library
- 3 years ago
Let me know if there is any other concern at your end.
It compiles it in a libray and can be used in other vhdl modules that are compiled in the same lib.
If the library is different then it won't use it.
Thanks AEsqu!
is that a physical library (path)?
if so, how can i locate the full path?
i have a library with the same name under the qsys ip path generated by the platform designer (see in red below) are this is the library pointed in the qsf?
if so, will the files physically located in this path included in the PROP_Interface_wrapper_10 library although not specifically motioned in the qsf?
....\source\qsys_Omni_dBGO_main\ip\MR_DMOD_NIOS\MR_DMOD_NIOS_PROP_Interface_wrapper_0\PROP_Interface_wrapper_10\synth
- AEsqu3 years ago
Contributor
No it is not a path, it is just a library name where the VHDL files are compiled in the compiler database.
In VHDL RTL code , there are used this way for example:
library IEEE;
use IEEE.std_logic_1164.all;If no library are specified, they all go under the same work lib normally.
- yossik3 years ago
Thanks AEsqu
