11 years agoSecurity feature in Quartus
Hi, I'd like to use the security feature of my stratix IV. But, it seems that a non-volatile key has already been programmed. When I try to program my ekp file, Quartus says : "Programming ...
11 years agoNon-volatile key is one time programmable (OTP). So when the OTP key is there you cannot reverse the process,and you cannot overwrite with the volatile key. EKP shud have the information of the key. If u want to further understand the file, you can convert the EKP to SVF format.and u will see it clearly.
