11 years agoSecurely start a State-Machine with pulses or edges
Hi there, this problem occures in my work from time to time: I want to start a State-Machine (Transition from Idle-State S000 to State S010) either with a single one-clock-pulse or on the edg...
11 years ago --- Quote Start --- There is only one way and is surest securest: sample the pulse on the clock edge and use same clock edge as that generated it --- Quote End --- ie.
signal ip_r : std_logic;
process(clk)
begin
if rising_edge(clk) then
ip_r <= ip;
if ip_r = '0' and ip = '1' then
--action on rising edge
elsif ip_r = '1' and ip = '0' then
--action on falling edge
end if;
end if;
end process;
Assuming there are no timing failures this will ALWAYS work. --- Quote Start --- If sampling fails and the clock edge did not see the pulse then either timing is not right or else your logic is not right. We trust the technology otherwise we wouldn't be here. --- Quote End --- Timequest will tell you if theres a timing problem A good testbench will tell you if theres a logic problem. Fixing either is usually acheived through modifying the code. Fixing timing problems with extra SDC constraints should be the last resort.
