11 years agoSecurely start a State-Machine with pulses or edges
Hi there, this problem occures in my work from time to time: I want to start a State-Machine (Transition from Idle-State S000 to State S010) either with a single one-clock-pulse or on the edg...
11 years agoNow it seems that we're slowly on the same level. Right, the Start_IN signal is already from a synchronized core with a synchronous reset, is read in synchronous by the second core (which also has an synchronous reset) and the result is on synchronous outputs. No asynchronous logic in between.
Well, now the really generalized question is (see initial post) what are the best (securest) ways to detect edges or one-clock-pulses (everything synchronized) to trigger the start of a state-machine. This is a general question and not for debugging a special code. I will ask, if I can publish my code to you. (Company problem) PS: I think there are so much "synchronous" in this post, we can call Guinness. :) PPS: To be sure: synchronous :D
