11 years agoSDR Implimenation
I am currently working on SDR as my M.tech Thesis..I got a link from YOUTUBE about this link http://www.arrow.com/beradio by ALTERA SDR Implementation of BeRadio.......This link(udpsdr_hf0_12272012.q...
11 years agoThere are many different open source SDR out there.
AM/OOK Modulation/Demodulation is the simplest. A simply way to channelize your band is to just use and FFT then run the resulting bins through a square rooter, then a correlator. If you need FM/FSK/GFSK/PSK you will need a CORDIC (which can also be used to give you the Square root) Pete
