13 years agoSDC set_input_delay and set_output_delay constraints
Hello, I'm new to TimeQuest / SDC commands. In my design I've got an external Ethernet switch device that is sourcing a dedicated clock signal to drive data into an FPGA. The switch device al...
13 years agoThanks kaz and rbugalho for your responses.
The device is a KSZ8995MAI ethernet switch. I have attached a snapshot of the timing info from the datasheet. The datasheet provides an "output valid" parameter for the data lines that the switch sends data to the fpga on; this is spec'd as a min of 18 ns and max of 28 ns. Below is what I have in my SDC file so far (updated based on your feedback). Based on the attached info, does this seem correct? I have not factored in board delay yet, but I would expect no more than 2 ns based on my board design. Since the clock and data originate from the switch, if we assume trace lines are the same length, I wouldn't need to constrain anything on the FPGA's receive data lines, correct? Note that mii_mrxd and mii_mtxd are data signals defined in my design. create_clock -name {mii_txclk_25mhz_in} -period 40.000 -waveform { 0.000 20.000 } [get_ports {mii_mtxclk}] create_clock -name {mii_rxclk_25mhz_in} -period 40.000 -waveform { 0.000 20.000 } [get_ports {mii_mrxclk}] set_input_delay -max -clock [get_clocks {mii_rxclk_25mhz}] 28 [get_ports {mii_mrxd [*]}] set_input_delay -min -clock [get_clocks {mii_rxclk_25mhz}] -12 [get_ports {mii_mrxd [*]}] set_output_delay -max -clock [get_clocks {mii_txclk_25mhz}] 10 [get_ports {mii_mtxd [*]}] set_output_delay -min -clock [get_clocks {mii_txclk_25mhz}] 0 [get_ports {mii_mtxd [*]}] Thanks in advance
