11 years ago
SDC file + Quartus II Text Editor issue
Hi guys,
I think that there is an issue with the text editor of Altera when I try to modify the SDC files. This text editor should be confgured to generate linux output in order to have LF instead of CRLF (https://en.wikipedia.org/wiki/newline). Because if this is not so, and you introduce a CRLF within a line, timequest misinterpret the TCL command. This for example happen when you are doing something like this in the SDC code:
set_clock_groups -asynchronous \
-group EXT_CLK125MHZ
-group [get_clocks $vid_clk]
-group [get_clocks $sys_clk]
-group $eth_rx_clock_group
-group $eth_tx_clock_group
#-group EXT_CLK080MHZ \
The quartus II text editor interpret this like a CRLF and when run the timequest, i get the error attached. However when i edit the SDC file out of the Altera text editor, I don't get any error because this text editor is using LF instead of CRLF.
Is there anywhere any option in order to configure the LF in the Quartus II text editor?
