amildm
Contributor
3 years agoSDC directives in HDL
Hi All,
Is it possible to add the SDC directives (e.g. set_false_path) directly in HDL?
Thank you!
FvM
3 years agoHello,
a simple example. You have a synchronizer register in a VHDL entity and want a set_false_path statement added for each instance in the design automatically. As SDC uses hierarchical object names, the entity name must be unique.
ARCHITECTURE rtl OF ce_sync IS SIGNAL ce_toggle : STD_LOGIC := '0'; attribute altera_attribute : string; attribute altera_attribute of rtl : architecture is "-name SDC_STATEMENT ""set_false_path -from [get_registers *ce_sync:*|ce_toggle]""";
Multiple SDC statements can be placed in the attribute statement by string concatenation.
Frank
amildm
Contributor
3 years agoCould the same be done for Verilog as well? What's the syntax?
