9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years ago --- Quote Start --- With regards to your original question here, the answer is neither. You should be adding a virtual clock constraint to define the external clock that is driving the upstream device that is providing signal_x to the FPGA. A virtual clock is created with create_clock and no target because it never actually enters the FPGA device. So it might look something like this (the numbers are just examples): create_clock -name clock_virtual -period 10.0 create_clock -name clock_x -period 10.0 [get_ports {clock_x}] derive_pll_clocks set_input_delay -max 5 -clock clock_virtual [get_ports {signal_x}] set_input_delay -min 1 -clock clock_virtual [get_ports {signal_x}] --- Quote End --- Then, do you consider clock_virtual as being asynchronous to clock_x? My question is about setting the clock groups with the set_clock_groups command.
