9 years agoSDC - What clock should the input pin be relative to?
Hello, signal_x in an input pin to my FPGA. signal_x is synchronous to clock_x which is also an input pin. clock_x drives a pll input and becomes pll_clock_x. pll_clock_x is pha...
9 years agoIt's an integer PLL
The set_input_delay min is 0.1ns The set_input_delay max is 10ns The period is 25ns (40Mhz). Regarding the "derive_pll_clocks" command - yes. I used it and requested it to create the base clocks. So I didn't have to manually use neither create_clock nor create_generated_clock - all have been done automatically by the tool via the derive_pll_clocks command.
