8 years ago
SCFIFO in LE-mode: empty and full not affected by write/read
I am implementing a small Avalon-ST buffer using the SCFIFO in showahead mode implemented as LEs. I converted my project from Quartus Pro 17.1 to Pro 18.0 and since then I have had problems with the empty/full signals. When I write to the FIFO, the usedw signal is incremented as it should but empty and full don't chance.
In the attached SignalTap screenshot I am writing my second two-word packet to the FIFO. Usedw starts from 2 and the FIFO goes full, but the status signals don't chance.
At closer inspection with RTL Viewer, the empty and full signals seem to be static values generated in the fifo_state (a_fefifo) module. I have attached a picture of that as well.
Is this a bug in the FIFO implementation, or is there something wrong with my parameters or some change in the recent version I have not noticed? I am now compiling the project with the FIFOs implemented on RAM blocks for testing.
I am using the following parameters to instantiate the FIFO (ram output register and over/underflow checks were previously on):
    parameter BYTES         = 32,
    parameter WIDTH         = 8,
    parameter CHANNELS      = 4,
    parameter ERROR_WIDTH   = 2,
    parameter DEVICE_FAMILY = "Arria 10",
    parameter BUFFER_DEPTH  = 4
    scfifo# (
        .intended_device_family  (DEVICE_FAMILY),
        .lpm_width               (BYTES*WIDTH + $clog2(BYTES) + 2 + $clog2(CHANNELS) + ERROR_WIDTH),
        .lpm_widthu              ($clog2(BUFFER_DEPTH)),
        .lpm_numwords            (BUFFER_DEPTH),
        .lpm_type                ("scfifo"),
        .enable_ecc              ("FALSE"),
        .add_ram_output_register ("OFF"),
        .lpm_showahead           ("ON"),
        .overflow_checking       ("OFF"),
        .underflow_checking      ("OFF"),
        .use_eab                 ("OFF")
    ) fifo_buf (
        .clock                   (clk),
        .wrreq                   (in.valid & ~fifo_full),
        .data                   ({in.data, in.empty, in.sop, in.eop, in.channel, in.error}),
        .usedw                   (fifo_usedw),
        .full                    (fifo_full),
        .empty                   (fifo_empty),
        .rdreq                   (out.ready & out.valid),
        .q                      ({out.data, out.empty, out.sop, out.eop, out.channel, out.error}),
        .aclr                    (arsthttps://alteraforum.com/forum/attachment.php?attachmentid=15725&stc=1https://alteraforum.com/forum/attachment.php?attachmentid=15726&stc=1),
        .almost_empty            (),
        .almost_full             (),
        .eccstatus               (),
        .sclr                    ()
Edit: Switching to RAM-implemented FIFO worked, but still curious to find out why this happened.
