13 years ago --- Quote Start --- Now I want another Bidir pin on FPGA which is a copy of EXT_MDIO Bidir pin. can I do that? --- Quote End --- Referring to post# 3, think in "hardware". You have two input signals from two bidir pins. You can route them to one internal bidir signal, if you have a select signal that controls a 2:1 MUX between external and internal input ports. In addition, the internal output enable signal for the bidir port must be accessible.
