18 years ago --- Quote Start --- Hi, The 360 input signals are unrelated so they won't arrive at the chip at the exact same time. But they never crossing into each other domain. So I think the two constraints listed above should result into the same result. Am I wrong? --- Quote End --- You are correct. If each domain is independent in the design you can apply one clock constraint to them all.
