King22
3 years agos10 fpll can't lock in quartus 22.4
Hi All
I use s10 fpga , and the compiler is quartus22.4 , in my design , I use a fpll as transceiver pll , but the fpll can not lock , but when I use quartus21.1 to compile , fpll get lock...
AqidAyman_Altera
3 years agoHi King22,
No problem.
The internal team ask for the confirmation on below situation that you faced:
- 21.1, 4 transceiver channels - crash with internal error
- 21.1, <4 transceiver channels - can compile, fpll can lock
- 22.4, 4 transceiver channels - can compile, fpll cannot lock
- 22.4, <4 transceiver channels - can compile, fpll cannot lock
Is it accurate?
Aqid
- King223 years ago
Hi AqidAyman
I modify first 2 item as below
- 21.1, >4 transceiver channels - crash with internal error
- 21.1, =<4 transceiver channels - can compile, fpll can lock
Above case is that , fpll's source is from io_pll
and if I use differential clk as fpll'a source , Q22.4's fpll will locked
BRs
King22
