GDeXi
6 years agoS10 EMIF IP Error Report
My EMIF is set to ping-pong PHY, because the device contains two teams of CK, CKE, cs_n, ODT, but in the plan stage, such errors are always reported: Error(18612): READDATAVALID signal for sec...
Deshi_Intel
6 years agoHi,
The error message description doesn't complain about EMIF Ping Pong PHY setting but rather more on the EMIF interface avalon connection issue.
Can you check back your Platform designer (or previously QSYS) design on the EMIF IP avalon port connection ?
make sure you export it to QSYS top level file as "conduit"
dlim
GDeXi
6 years agoHi,I have already change my QSYS export as "conduit" . like follow :
but is still report error,thanks for you reply
