8 years agorunning timing analysis without fitter first
Hi, whenever i initiate TimeQuest quartus seem to start by default the Fitter...is that a default operation or something is wrong in my project? I guess it should be feasible to just run synthe...
8 years agoWhat to do when the project was build by a script: i.e. OpenCL project build script? When I try to run timing analyzer it still gives this error: "ERROR: Can't run TimeQuest Timing Analyzer (quartus_sta) -- Fitter (quartus_fit) failed or was not run. Run the Fitter (quartus_fit) successfully before running the TimeQuest analyzer (create_timing_netlist)." Is there a way to still run timing analysis for example to re-write our base.sdc constraints?
