8 years agorunning timing analysis without fitter first
Hi, whenever i initiate TimeQuest quartus seem to start by default the Fitter...is that a default operation or something is wrong in my project? I guess it should be feasible to just run synthe...
8 years agoOn older device families (before the generation 10 devices, I believe), you can just synthesize your design, then manually select to create a post-map timing netlist in TimeQuest. On newer devices, I think you have to run the Fitter first all the time.
