11 years agoRunning a simulation in Modelsim
Hi, Appreciate your help regarding running simulations in Modelsim. I have a set of modelsim files that runs on modelsim altera starter edition version 10.0c. I have check and it works. It does...
11 years agoModelSim altera starter edition 10.0c is compatible with Quartus II 11.1 .
If you are not using Quartus II 11.1, you may need to upgrade the modelsim to compatible with your Quartus II version. Below are the text from <modelsim install path>/altera/version.txt for Quartus II 11.1. *********** Model Technology ModelSim ALTERA 10.0c Libraries compatible with : Quartus II 32-bit ShellVersion 11.1 Build 259 01/25/2012 Service Pack 2 SJ Full Version Note : Please use ONLY with Quartus II Install version to avoid incompatibility issues. *********
