Run Platform Designer from pre_flow_script fails
- 6 years ago
Looking into the user guide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_intro.pdf page 6 - 23. it seems to be only way to create this html file through the Platform designer. If Quartus failed to generate automatically, we can have an enhancement on this,
Hello, thank you for the fast answer, I was out of office for a while.
I noticed that Quartus Lite automatically generate the output files, nevertheless it does not generate all of them.
In particular, according to our workflow, we need the html file generated by Platform Designer, which seems to be created only when the qsys-generate.exe command is executed, either through the GUI or from the shell.
Do you know how to generate it without the user manual intervention?
