SFava
6 years agoRun Platform Designer from pre_flow_script fails
Hello, The Context I am trying to automatize the whole Quartus design flow so that when starting the Compilation flow I will get: automatic generation of the system through Platform Designer all...
- 6 years ago
Looking into the user guide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/qts/qsys_intro.pdf page 6 - 23. it seems to be only way to create this html file through the Platform designer. If Quartus failed to generate automatically, we can have an enhancement on this,
KennyT_altera
6 years agoUnlike Quartus Pro, Quartus lite should auto generate those qsys files in every compilation. You can look into assignment -> settings -> IP settings -> Always regenerate IP files for IP cores.
What you need to do is include your design with an .qsys files instead of .qip files. You should not need any script to do the work.
