8 years agoRun Functional Simulation Error
I've just installed the QUARTUS II, and i am trying to run a simulation because i'm receiving the message below, can i have help solving this please? thanks Device family: MAX7000S Running quartus ...
8 years agoHi,
Check the below thread which discuss on same issues. https://alteraforum.com/forum/showthread.php?t=44213 To work around this problem, perform the following steps Make the file <Quartus II installation directory>\modelsim_ase\modelsim.ini writable. For example on Windows, right-click the file, select properties from the context menu and turn off the read-only option Add the following line to modelsim.ini: max7000s = /../altera/verilog/max Best Regards, Anand Raj Shankar (This message was posted on behalf of Intel Corporation)
