TYiyu
5 years agorun examples in quartus prime pro 20.2
I installed the quartus prime pro 20.2 in my desktop. The OS is CentOS 7.2. I installed the device library Arria 10, Stratix 10, Agilex and the simulation tools is Modelsim ae. The installation...
EBERLAZARE_I_Intel
5 years agoHi,
Can you run below and share the log again:
make test-x86-64
make test-fpga
Reference can be found below on page 16:
TYiyu
5 years agoHi,
I run the commands you mentioned by the example counter on the directory hls/example/counter
make test-x86-64 : execution is successful
make test-fpga: same errors occurred. The debug.log is attached.
Thanks a lot.
Yiyu
- EBERLAZARE_I_Intel5 years ago
Please follow and setup thoroughly the Getting started guide:
Especially on page 10 where you set up the environment for the "ini_hls.sh" etc, once done, please re-do the tutorial again.
