hazeltet845
4 years agoRule C101 and PLL output clock
I am using Quartus II 10.1 and keep receiving the critical warning "Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) ...
- 4 years ago
There is a Knowledge article for this issue. Following is the link for it. Please refer.
sstrell
4 years agoIs this your full design code? Can you post your edited code? Are you sure the design assistant rule warning is applying to this part of the design? And what is your .sdc look like?
