hazeltet845
4 years agoRule C101 and PLL output clock
I am using Quartus II 10.1 and keep receiving the critical warning "Critical Warning: (Critical) Rule C101: Gated clock should be implemented according to the Altera standard scheme. Found 1 node(s) ...
- 4 years ago
There is a Knowledge article for this issue. Following is the link for it. Please refer.
sstrell
4 years agoIf you're coding for an asynchronous clear, you should include reset in the sensitivity list. If this is supposed to be a synchronous reset, the reset should be after the rising edge check (and not in the sensitivity list).
