8 years agoRTL module+OpenCL-top file synth .v from .cl can't find clock,resetn,AvalonST signals
Hi, I'm trying to get a customised FFT1D example working. Basically it is the same as the example fft1d from the library, except I am adding in an RTL module which executes an XOR function. The...
8 years agoI have never personally done this, but Altera has a library design example here:
https://www.altera.com/support/support-resources/design-examples/design-software/opencl/library-design-example.html You can take a look at the example and see if you can fix the problem by imitating what is done by Altera.
