DNguy4
6 years agoRST_N port of pll
I add a simple pll to my design and i continue to run into the following error even though i don't have that port. Error: RST_N port on the PLL is not properly connected on instance SOC_27Mhz_clk|io...
Rahul_S_Intel1
6 years agoHi ,
May be the below KDB may be use for your debugging.
https://www.intel.com/content/www/us/en/programmable/support/support-resources/knowledge-base/component/2017/14--why-do-i-see-the-error-error--rstn-port-on-the-pll-is-not-pr.html?wapkw=Error:%20%22RST_N%22%20port%20on%20the%20PLL%20is%20not%20properly%20connected%20on%20instance
