9 years agoRS232 UART not generated correctly in Quartus 17.0
I have a Quartus 16.1 project where I generated an "RS232 UART" from the IP Catalog and it worked fine. When I try to do this in a newer Quartus 17.0 project, it does not work correctly. I did a diff...
9 years agoBased on your description and the tests you've tried, this sounds like a bug. Raise a ticket via myaltera (https://www.altera.com/mal-all/mal-signin.html).
Cheers, Alex
