11 years agoRS232 rxd code
Hi :) i'm new here and i need some help... i work on project and i need to read from kind of machine some letters... there is an ascii code to all letter. this machine send words that i ne...
11 years ago --- Quote Start --- Have you run a simulation? Have you verified the reiceiver works as expected? I assume you always check in the middle of the bit? --- Quote End --- yes yes by c# and work perfect... i think is about a lot of bits are sent... Hmm...how do i check in the middle of the bit?
