11 years agoRS232 rxd code
Hi :) i'm new here and i need some help... i work on project and i need to read from kind of machine some letters... there is an ascii code to all letter. this machine send words that i ne...
11 years ago --- Quote Start --- Then you compare the received bits with a bitmask for your char. Or am I missing something? --- Quote End --- yes... for example: the code ascii of letter "Y" is "01011001" by ascii table... and if mvme162 transmit the letter "Y" so the led<='1', but then i the code in the altera (cyclone ii) the led is always '0' and noything cahange... and i can see that mvme162 transmit.
