TMVector
5 years agoRouting Back Annotation in Quartus Prime Pro
Hi there,
I am trying to generate an RCF (routing constraints file), but it isn't an option in the "Back-Annotate Assignments" dialog box, and running via CLI just gives a warning.
The help docu...
- 4 years ago
Hi Jonny,
I think you should use logiclock_back_annotate -routing instead.
You can refer to section 3.1.1.2 of this document: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-scripting.pdf#page=71
Nurina
TMVector
4 years agoHi Nurina,
Thanks for your reply -- it was very helpful and looks to be the right path. I haven't managed to confirm it yet because it's a part time project and the build is currently failing on a different issue, so routing back-annotation won't run yet. Once I have fixed that, I will post an update that will hopefully be helpful for others (and serve to remind me in the future!).
Jonny
