Possible issue 1: you still have ZZs in the "others" case. Avoid having Z and bi-directional signals on you design, except on the I/O pins.
Possible issue 2: That code can't be implemented in a RAM block and thus will be implemented into logic elements, which increases time and design. Try to use a design that can be implemented in a RAM block and matches Quartus ROM inference templates.
An alternative I like for such cases is to LPM_ROM block primitive with .HEX files.
You can also use .MIF instead of .HEX. .MIF have a simpler format, but they're not supported by ModelSIm.
rom : lpm_rom
generic map (
LPM_WIDTH => 8,
LPM_WIDTHAD => 14,
LPM_FILE => "rom.hex",
LPM_ADDRESS_CONTROL => "UNREGISTERED",
LPM_OUTDATA => "REGISTERED"
port map(
outclock => Clk,
address => A,
q => D
