9 years agoRidiculous interconnect timing between related clocks
I'm trying to finalize a design in an Arria 10, using Quartus Prime Pro 16.1 , where a signal is passed from a global clock to a related peripheral clock of the same frequency (they are both derived ...
9 years ago --- Quote Start --- Good call on checking what the routing was trying to do - turns out it actually was routing the signal half way round the device in an attempt to make a hold requirement that is utterly nuts! I'm working on playing with multicycle constraints to get it to actually analyze the path in a more sane way... Thanks all for the help! --- Quote End --- This is identical to a problem I had to a global fanout async reset. The Reset was coming from an synchronous source, and for some reason, it decided that a reg somewhere had some crazy hold requirement, and hence routed the single output through a global buffer (as expected), then through some logic on the edge of the chip, then fanout all over the chip giving me 1000s of recovery violations up to 10ns (in a S4) Solution (as supplied by altera) was to relax the hold time on the fanout of this reg, and the problem went away.
