9 years agoRidiculous interconnect timing between related clocks
I'm trying to finalize a design in an Arria 10, using Quartus Prime Pro 16.1 , where a signal is passed from a global clock to a related peripheral clock of the same frequency (they are both derived ...
9 years agoYes, I have seen long timing paths due to routing delays in A10 designs. Check for congestion in the chip-planner. Also locate failing path and select highlight routing. If it takes multi-segment routes you may have an issue of available routing resources. Post a picture of your routing wire utilization. Good luck!
