emaferna
5 years agoReusing components: basics
Hello, using QUARTUS PRIME (LITE EDITION):
I wrote and tested an easy myAND2 basic project in a folder "progetto_myAND2".
I wrote and tested an easy myOR2 basic project in a folder "progetto_myOR...
emaferna
5 years agoHello,
I solved it by entering the paths of the source files of each respective project using: Setting-Files-Add
Source files are used during compilation, referencing them and not copying them.
Question: but there is no way to create a compiled library from QUARTUS and not MODELSIM to be reused?
KhaiChein_Y_Intel
5 years agoHi,
It is glad that you solved the initial problem. Could you elaborate your new question? Could you share what you are trying to do?
KhaiY
