15 years ago
reuse wires in Quartus
hi,i 'm almost new to quartus.
how can i use a wire that is not name of input or output pin as input of another component(4 example as input of a buffer)?
i don't want to connect it directly...
    actually I don't have enough confidence. if I get what you ask...
    "assign" may be you meant.
    refer this.
    input A;
    output B;
    wire C,D;
    assign C = A; // now C means A.
    assign D = B; // now D means B.
    yes,i think akira is right.
    Without being worried abt input or output,u can just type keyword "wire" and "assign" and give values whatever it is depends on ur code condition.the simple meaning of "wire" in quartus is "constant"
    So u can "Assign" to give them values.
    With the reference of above code,if u wanna b sured then after compiling ur code,u just observes signals in "vector waveform file",it will show u only input and output signals only.No
    "wire",no "registers"
