15 years ago --- Quote Start --- Without the "NOT Gate Push-Back" option, Quartus can't synthesize registers with asynchronous set. Please notice, that I only assume, that the option is the reason why you see a wrong register content. The more important question is, if the register's initial value is correctly seen by the design. --- Quote End --- the reset signal works correct in the design, but the failure of initial value loading makes it difficult to perform the timing simulation.
