15 years agoi don't think it is a bug of code,
it was been proved by hardware test, it will restore the RESET_VALUE at the start point. below is the part which act abnormal in simulation.
1.
module eth_register(DataIn, DataOut, Write, Clk, Reset, SyncReset);
parameter WIDTH = 8; // default parameter of the register width
parameter RESET_VALUE = 0;
input DataIn;
input Write;
input Clk;
input Reset;
input SyncReset;
output DataOut;
reg DataOut;
always @ (posedge Clk or posedge Reset)
begin
if(Reset)
begin
DataOut<=#1 RESET_VALUE;
end
else if(SyncReset)
begin
end
else if(Write) // write
begin
DataOut<=#1 DataIn;
end
end
endmodule // Register
2.
//here is the module initialization code
//'ETH_PACKETLEN_DEF_0 was defined as 8'hee.
eth_register# (`ETH_PACKETLEN_WIDTH_0, `ETH_PACKETLEN_DEF_0) PACKETLEN_0
.DataIn (DataIn),
.DataOut (PACKETLENOut),
.Write (PACKETLEN_Wr),
.Clk (Busclk),
.Reset (Reset),
.SyncReset (1'b0)
3.
cycloneii_routing_wire inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_DATAIN_routing_wire_inst (
.datain(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_a17_combout),
.dataout(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_DATAIN_driver));
cycloneii_routing_wire inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ACLR_routing_wire_inst (
.datain(inst_aeth_A_aReset_aclkctrl_outclk),
.dataout(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ACLR_driver));
cycloneii_routing_wire inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ENA_routing_wire_inst (
.datain(inst_aeth_A_aethreg1_aPACKETLEN_Wr_a2_a_a4_combout),
.dataout(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ENA_driver));
// atom is at LCFF_X34_Y19_N9
cycloneii_lcell_ff inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a(
.clk(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_CLK_driver),
.datain(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_DATAIN_driver),
.sdata(gnd),
.aclr(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ACLR_driver),
.sclr(gnd),
.sload(gnd),
.ena(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut_a6_a_ENA_driver),
.devclrn(devclrn),
.devpor(devpor),
.regout(inst_aeth_A_aethreg1_aPACKETLEN_0_aDataOut));
code 1 is register's rtl code. code 2 is one implementation of register. code 3 is the code i found in vo files, which describes the dataout[6] pin value. the value of this reg should be 1 after reset. but in this code the reset signal was connected with ACLR pin of the lcell_ff, in whose simulation source file, aclr pin would only reset the inner register to 0.
